-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   oil sending unit on cpi? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/oil-sending-unit-cpi-89170/)
chris015 03-10-2015 07:47 PM
Scrolling down the road i look down to see a awesome 10 psi of oil pressure. 0 at idle. Slammed it in Neutral,key off,Pulled over,checked oil,oils perfect. I know it has pressure as the engines not making a bit of noise. Im guessing sending units bad. for kicks, Stopped by napa and got a wix filter (ruling out callasped filter). swapped it. Seems to be fine now but with ignition on the oil gauge pegs (bad ground?) on sensor.
So i might change it,but do to the fact it looks like i have to pull the distributor to get to it,i might install a mechanical and be done with it.
Isnt there a fitting near the oil filter i can use? I cant remember.
I tell ya,it scared the poo out of me when i noticed the pressure. Sucked.
