Over-torqued Manifold bolts 3-5 pounds
Old Sep 30, 2013 | 06:25 PM
TennesseeBoy's Avatar
TennesseeBoy is on a distinguished road
Default Over-torqued Manifold bolts 3-5 pounds
Just replaced my CPI and lower intake gasket only to discover I over torqued the lower manifold intake bolts somewhere between 3-5 ft/lb (normal is 35 ft/lb) Didn't hear any popping, went really slow, torque wrench popped and I stopped. Should have double checked my math.
Do I need to back them off one at a time in sequence and re-torque? Or will it be ok? Please don't say I need to tear it back down!
Any input is appreciated.
TH
Old Sep 30, 2013 | 08:19 PM
chris015's Avatar
meh. i wouldnt worry about it. 99% of the time the do-it-yourselvers just crank em down with a socket wrench and be done with it. if its not leaking in the oil,and not outside. call it done.
props at using a torque wrench!
Old Sep 30, 2013 | 08:21 PM
I'm going to rent a coolant system pressure tester from O'Reillys, that should tell me if my gasket is toast I guess. Hopefully it's ok. Guess that's what I get for using a torque wrench in inch pounds and a calculator.
castiglian
Sep 13, 2014 04:39 AM
seaglassman
Aug 25, 2013 10:41 AM
evuldrporkchop
Headers, Intake, & Exhaust
Feb 23, 2013 05:53 PM
pontiacg5
Oct 15, 2010 06:38 AM
bertrenolds
Apr 12, 2008 02:23 PM
