prop valve bad again... need serious help-
Old Jun 18, 2012 | 05:50 PM
NT_Hardcore's Avatar
NT_Hardcore is on a distinguished road
Default prop valve bad again... need serious help-
ok so i replaced a leaky prop valve a few months ago. i figured it was old and just went out. today driving i lost brakes. no stopping at all. parked and had someone press the pedal and the prop valve is leaking at the joint where the rear line exits the valve. my question is why does this keep happening and is there a way to get rid of this valve? im ordering another but i dont wann go thru this again. i do not have ABS. this is an 87 s 10 blazer. any advise would be great. if anymore info is needed ask and ill do my best to answer.
Old Jun 18, 2012 | 07:17 PM
Blazin_Jason's Avatar
Might be from the bass? Post a pic. His were braking in other places I think.
Old Jun 18, 2012 | 07:18 PM
im sure it is. the steel bracket that it mounts too is torn almost in half. ill have to get pics tomorrow as the truck is at work.
Old Jun 18, 2012 | 08:02 PM
can i use something like this on the back line and run the fronts straight off the master?
New Adjustable PROPORTIONING VALVE w/fittings for 3/16" brake line,knurled **** | eBay
Old Jun 18, 2012 | 08:44 PM
abig84's Avatar
yep. people do it all the time, especially when they build custom trucks, like offroad buggies or beater mud trucks.
i was gonna go that route with my 86 k30 but figured out the problem i was having wasnt the prop valve.
only thing that is going to suck is running all those lines, the proportioning valves always use screwy ends so doubtful you will be able to find unions to by pass the prop valve so you will either have to cut and compression fitting them (i hate using those things) or run all new lines
also i have no idea how the heck you go about adjusting that thing. how do you know what percentage your rear brakes are at. i would think in the winter you could mess with it till all 4 wheels slide but youre gonna be doing a lot of adjusting and driving
bertrenolds
Mar 8, 2012 09:17 AM
Doverman454
Aug 14, 2010 11:46 PM
Denominator
Feb 23, 2010 03:40 PM
tankie88
Oct 30, 2006 07:58 AM
bowanna03
Oct 1, 2006 03:10 PM
