-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   rear window squeak (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/rear-window-squeak-6729/)
rooster 11-19-2006 10:07 AM
rear window squeak
does anyone know why and how to stop the rear window from squeaking, it looks like the window slides sideways when i go over any bumps but squeaks all day long and is getting on my nerves. ive glued a piece of rubber to the bottom to make a tighter fit and ive tightened the bolts on top. yet squeak squeak everywhere i go. pls help
sledneck16 11-19-2006 03:37 PM
RE: rear window squeak
what you need is some sort of clear drying silicone lubricant----put some on ALL of your seals on your truck and they wont squeak until it wears off in a few months---then repeat. [8D]
oh and try not to get any on your paint---might not react well depending on what you use
bat119 11-19-2006 03:46 PM
On my 99 blazer I had the same problem, to stop the squeak I wrapped fiberglass tape around the bar that goes into the catch (2 wraps) it has held for a month so far.
swartlkk 11-19-2006 11:30 PM
The rear window latch can be adjusted, but it involves the removal of the interior trim. Then there are 2 nuts that need to be loosened to adjust. I did a little how-to a long time ago, but it never made it into the DIY section.
RedBlaze 11-20-2006 12:01 AM
for a quick and easy fix all i did was wrap some electrical tape around the bar that goes in the latch. if you dont open up your backglass a whole lot it will hold for a good while.
Chevy Lover 11-20-2006 03:50 AM
How about the end gate? Is it adjusted tight? I've heard of the endgate being loose between the latch and the striker, which could also cause a squeak on the window.
Annekat91 11-20-2006 01:55 PM
A couple shots of WD 40 in the latch, and wiggle the latch in between squirts, can work for awhile, too. An immediate fix to stop the noise until you can get around to the better fixes.
Anne
White '91 2 dr S-10 Blazer
4X4, 4.3L, automatic
Sunroof, running boards
151,000 miles
blazinloud 12-05-2007 09:02 PM
sweet!
mine almost makes me cry :(
wow, this thread is almost 2 years old......
error_401 12-08-2007 04:31 AM
I've started simply greasing the catch which is the source of the noise in mine.
Holds as long as electrical tape or other remedy.
dimmuborgir6nik6 12-08-2007 04:33 AM
Mine never used to squeak, but tonight I noticed it's starting to.
I've also noticed that it doesn't open all the way automatically anymore. It goes up halfway and I have to push it the rest of the way up.
I think with all this snow, the rocksalt could've messed it up.
