Replace Throttle Position Sensor TPS In Carburetor
How hard is it to replace the Throttle Position Sensor on a Rochester E2SE carburetor V6 2.8L the piece of **** Haynes manual show's kinda how the guy pulls it out when he is rebuilding the carb, but does that mean I have to take the carb apart, and I can't do it on the car while just removing 2 bolts or so to pop it out
my check engine light flashes code 21 which is the TPS
You are going to have to remove the upper air horn to get the TPS sensor out. Are you sure that it is bad? Have you tested it with a multimeter for smooth voltage increase with throttle increase? You should not have over 0.65V at idle. 0.45V is the general area for the reading when on the hot idle cam. I am not sure how to adjust this though.. I rebuilt the E2SE on my old 85 S10 a LONG time ago, but never had an issue with the TPS.
Check out THIS PAGE for the exploded view.
I think it was just a loose connection plug, I unplugged it all the way blew on it (like my dad used to do) then plugged it back in, this time I heard it click, I think problem solved... will confirm after the drive home from work
on the way home from work the light came back on, so I took the negative cable off the battery for the night trying to clear the codes, and this morning after reconnecting the battery the Check Engine Light CEL came on as soon as I started the truck, so I don't think it was a loose connection. So how do I check the voltage of the Throttle Position Sensor TPS.
I spell things out so when people do searches they can find these posts, CEL, TPS, etc. and maybe find them helpful and meaningful.
russ1609
Jan 30, 2012 07:08 PM
seanpconley
Nov 1, 2010 05:01 AM
86Blazer4x4
Jun 14, 2009 11:52 PM
zombiewoof
Feb 12, 2008 09:13 PM
disturbedgame
Feb 12, 2008 05:32 PM
