-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Replacing Oil Pan Gasket (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/replacing-oil-pan-gasket-97206/)
mr.vls 06-29-2018 03:07 PM
Is it possible to replace the Oil Pan Gasket without removing the engine. This is on my 89 S15 2wd 4.3L Jimmy. I have an engine hoist so I could unbolt the motor mounts and raise the engine for some clearance if needed.
I do not need to remove the Oil Pan.
