rims ? for 83 chevy s10
will a 97 CHEVY blazer set of rims fit my 83 Chevy ?
You bet. Any RWD Gm wheel with 5 lugs should fit years 70-now... Take your pick. I think the half ton trucks with 5 lugs have a bigger pattern though. But from any muscle cars and earlier full sizes (?) should fit up just fine. Camaro/vette/montecarlo/s10/blazer can all interchange wheels, just to offsets might be different. You may need the lugnuts that match the shoulder of the nut hole inside the wheels though. Make sure you try and get the nuts that go with the new wheels too.
ok cause my truck is 2wd chevy s10 and its coming off of a 4x4 chevy blazer 97
Yeah they will work, the offset is no more than one inch on factory wheels. Should be fine. It means your wheels may stick out an inch farther to the outside than they do now.
Actually I think the rims will be sunk in.
i wont find out till tomorrow and i gota make sure they work or its a waste of money
