s-10 blazer body mounts
Would anyone be able to tell me what size bolts are on the body mounts for a 91 s-10 blazer 4-door and how many there are?
thanks for any help, mike |
RE: s-10 blazer body mounts
I don't know for sure but they should be easy to see. They probably have a 15mm head and there are probably 8 mounts.
I will not be offended if someone else knows for sure and corrects me...;) |
15mm is about right, but you should be able to see the bolts pretty easy. Pull out a socket and find out for sure.
There should be 10 body mount bolts. 2- on each side of the radiator core support, 2- right behind the front wheels, 2- under the passengers seats, 2 - in front of the rear axle, and 2- at the rear end. |
| All times are GMT -5. The time now is 04:41 PM. |
