-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   safe jacking/jackstand points? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/safe-jacking-jackstand-points-38640/)
musclecar70sfan 12-30-2009 12:17 PM
hey guys, I was wondering what are the jacking/jack stand points on my 94 S15 Jimmy. The only parts that I'm confident to use right now are the spare tire jack points. Thanks!
packofqtips 12-30-2009 01:08 PM
the entire frame works good
abig84 12-30-2009 01:10 PM
S10s have lots. Anywhere on the frame is fine. There should be a front crossmember under the engine that will work. Just dont use the radiator support. Rear axle works fine too
WolfPack 12-30-2009 02:40 PM
Originally Posted by abig84 (Post 281191)
{snip} Rear axle works fine too
As long as you have a jack that is safe to cradle the tube...otherwise...slippage is possible.
Ive also heard never jack on the differential housing, stick to the tubes.
Blazin_Jason 12-30-2009 02:57 PM
Eff that, I always jack up the pumpkin.
swartlkk 12-30-2009 04:32 PM
I have always jacked on the pumpkin as well. Never had an issue.
WolfPack 12-30-2009 04:56 PM
Weird. Wonder why the people who've told me that did..
Sisk 12-30-2009 05:59 PM
yeah i always use the pumpkin too. you have an entire frame to jack wit too dont forget. the frame is normaly pretty solid ;)
old skool luvr 12-30-2009 06:17 PM
i've never heard of that one either WolfPack.
besides the frame & diff, i've lifted off the LCA too. never had any issues-or slips.
it all comes down to how good of a jack you have. don't be trying to lift your truck with one of those 2 ton, 24" long jacks, they're just not stable. have a nice size 3 ton floor jack (or a sturdy set of ramps) for stability. even though your truck isn't low like qtips there, they make some nice low profile ones too.
NC93BLAZERLT 12-30-2009 07:17 PM
1 Attachment(s)
This works in a pinch!!! LMAO! Yes, I actually left it like this while I changed rear ends in NC!
