Serious idle problem
Old Jan 11, 2008 | 06:53 PM
jaimehcc's Avatar
jaimehcc is an unknown quantity at this point
Default Serious idle problem
94 S10 4.3l cpi runs good until it warms up, then all he** breaks loose. Bearly will idle, surging, popping, give it gas and it smooths right out.
I've been dealing with other issues for a while now. It wouldn't start, when it was cold, as a result of low fuel pressure, installed a new OEM pump, and it starts like a champ now!
Replaced a leaky FPR, tested the TPS and MAP with the old multimeter and replaced them, checked timing, replaced plugs, oil pressure sender, fuel filter, checked timing. I've spent untold hours looking for vacum leaks, replaced vacum hoses and air filter.
I've wrenched on non-fuel injected vehicles for a lot of years, but I just can't seem to solve this one.
Old Jan 11, 2008 | 10:12 PM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
Default RE: Serious idle problem
I have and still have the same problem, try cleaning the EGR
Old Jan 12, 2008 | 07:08 AM
jaimehcc's Avatar
Thanks, for the tip, already tried that one.
Old Jan 12, 2008 | 07:24 AM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
Any codes? Do you have a scan tool available? IF so, watch what the O2 sensor starts doing as the engine warms up. I suspect it is "sticking", and running the egine lean.
Old Jan 12, 2008 | 07:36 AM
jaimehcc's Avatar
No codes. Good tip on the O2 sensor, thanks for the reply.
Old Jan 16, 2008 | 01:04 PM
jaimehcc's Avatar
Replaced O2 sensor, old one had black sooty deposit(running rich?). It will still idle along fine, then start to drop Rpms, almost stall, exhaust pop, then either catch or stall completely. I am at my wits end on this one, anyone have a similar problem?
Old Oct 24, 2008 | 12:38 PM
ruxpin76's Avatar
ruxpin76 is an unknown quantity at this point
HAve the same issue, looking for answer too. usually stalls on idle. Disconnecting tan/white wire under passenger carpet gets me home, barely.
Old Oct 24, 2008 | 01:11 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
you seem to have quite alot of toolsdouble check that fuel pressure in regards to bleed off. When cold that 4.3 would demand more fuel where when warm.....I have no doubt that pressure is right there at key on(60ish probably)but when you key off-that's what I'd want to see. My thought is the GM 'nut unit' that attaches to your FPR-or something else in the plenum. Just a free guess. JP
Bigmancason
Jun 23, 2011 02:23 PM
airmananderson420
Sep 5, 2010 07:34 PM
Doverman454
Aug 14, 2010 11:46 PM
Boyer2011
Tires and Wheels
Dec 12, 2009 09:47 PM
Snowwhite1g
Dec 30, 2008 02:23 AM
