Severe misfire , starving for fuel
Old Feb 17, 2010 | 08:36 AM
92S20blazer's Avatar
92S20blazer is on a distinguished road
Default Severe misfire , starving for fuel
I have been battling a compound issue here for 3 weeks now. NO spark or intermittant spark which was resolved by getting rid of the junk borg warner cap and rotor as well as finding a bad connection to my accell coil.
I now have uninterrupted spark. My tach always registered the spark signal though.
I am now running into a very choppy idle and severely lean issue. I know on the TBI models like my old one , it used the spark reference signal from the module to know when to fire the injectors. I replaced that. Didn't run at all. Put a good known one in and back to full spark but still crap idle.
I have no converter on my truck so I can usually smell a little fuel smell in the exhaust. It's so lean that it smells like the truck is going to catch on fire. The heat from the exhaust is insane. I have tried swapping my old injector back (thought it was bad but it was the dam plastic fuel lines , replaced it about 4 years ago). Still same issue. I bought a fuel pressure gauge and it seems to hold fuel pressure just fine. I know the vortecs run over 55psi.
Do you think this could be a bad PCM? I am at the end of my ability to diagnose this thing.
Old Feb 17, 2010 | 09:42 AM
515Blazer's Avatar
515Blazer is on a distinguished road
could be the MAP sensor
Old Feb 18, 2010 | 09:42 AM
makes no difference wether the MAP is plugged in or not. Haven't tried swapping it out though , but unplugging it should make it do something different.
gmon3y15
Apr 2, 2014 12:18 AM
Repus J 13
16
Apr 6, 2012 09:37 PM
shligger
May 12, 2010 08:47 AM
kerander
Jun 5, 2009 01:50 PM
BlazinJake
Aug 29, 2008 07:35 PM
