-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   shorting out??? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/shorting-out-14558/)
docta J Nov 18, 2007 11:48 PM
shorting out???
i have a 93jimmy and the fuse for the horn/dm keeps shorting. i replaced the fuse and my horn worked and all of my dome lights. then a little later my lights stopped working and i realized that the fuse had gone. i had the correct amp fuse in, so thats not the problem. if anyone know anything about this, help would be greatly appreciated.
thank you
Hanr3 Nov 19, 2007 09:43 PM
RE: shorting out???
sounds like a intermittent short. The worst kind. You need to find it or it will drive you nuts until you do.
A bare spot on a wire will cause an imtermittent short, it will bounce and make contact with ground and short out sometimes.
docta J Nov 20, 2007 09:17 AM
RE: shorting out???
thanks i'll give it a try and let you know
