snapped leaf spring!!
hey guys i recently picked up a 93 s10 blazer 2wd. it has a clunking noise from the rear i thought it was a shock but today i found out that the passenger side leaf spring snapped off completely on the rear. i have access to a lift, is this a reasonable task? also, should i replace both sides? thanks for any input
replacing the leaf springs should be fairly straight foward and i would suggest replacing both sides also.
hope you got torches to cut out the bolts
| All times are GMT -5. The time now is 07:59 AM. |
