-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Starting problem fuel pump ??? (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/starting-problem-fuel-pump-9216/)
mblaszkiewicz Mar 9, 2007 12:39 AM
I have a 93 blazer with a 4.3 l v-6. Today it died at Wal-mart. If I let it sit for a while 10-20 min it tries to start then just cranks away. I tried the fuel bleeder (I think thats what it is called in the back of the engine). After the car sits it squirts fuel about 1-2 inches high for a second then dies off total (Key is in ON possition). When I crank over the engine with the bleeder depressed it squirts about 1/2 inch. Is this a fuel pump problem or something else?????
Any help would be thankful.
Mark
Hanr3 Mar 9, 2007 01:25 AM
RE: Starting problem fuel pump ???
Hard to say for sure without a fuel pressure test. Put a fuel tester on that port.
mblaszkiewicz Mar 9, 2007 01:34 AM
Thanks for the quick reply. Any idea where I can get a fuel pressure tester or can rent one. I ussually only do minor repairs now. Only have basic tools.
Hanr3 Mar 9, 2007 02:08 AM
Autozone has a great rent a tool program. You buy the tool, use it, then return it for a full refund, or keep it.
swartlkk Mar 12, 2007 10:27 AM
*Thread Locked*
Please reply to the thread linked to below:
Still not running
