-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Stripped Caliper Guide Bolt Fix (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/stripped-caliper-guide-bolt-fix-76507/)
c0a8l0v6i8n9 01-14-2013 11:28 AM
I bought my truck with stripped steering knuckles where the caliper bolt screws into. You can use an oversized bolt as a temporary fix, but eventually the threads will not longer hold.
Searched everywhere for the correct helicoil kit for the 1st Gen trucks. I installed this weekend in about 15 minutes.
Heli-Coil 55287 7/16-20 Kit
This is the correct kit. You will also need a 29/64 bit to drill the hole clean.
The kit does also NOT come with a tap handle but I screwed it in with a pair of adjustable vise grips.
KnightBlazer 10-11-2017 12:48 PM
I know this is a few years old now, but wanted to say thank you. Saved me a lot of searching. Just discovered this problem on my 94.
