Stronger rear axle for my 94
Hy guys I need to know what rear axle I can get that would def be stronger than my stock looking for one with disc brakes direct fit swap
We need a lot more info on this..
year make and model What you are trying to do that will require a "stronger rear axle" |
Stronger rear
It a 94 s10 Tahoe blazer two door I don't want to go strait axle in the front but I do want to be able to have an e locker I want a stronger rear that I know won't fail me under strain stock ten bolt is not very durable
Sounds like you'll need a custom built axle to me. You could throw a ZR2 axle in there but it'll be wide, hence custom to make it fit.
Maybe an Explorer axle? Not sure of the width but still would need to do some fab work. |
Rear axle
Ok thanks did not no zr2 was wider
