testing EGR & IAC
testing EGR & IAC
'93 GMC Jimmy 4x4 4-door auto with the cpi vortec v-6
Is there a way to test these? I'm showing trouble codes that seem to indicate faults with these 2 parts... I don't wanna shell out $190 for an EGR valve if it's not really broken.
RE: testing EGR & IAC
The electronic EGR valves typically don't go bad, but rather clog. You may want to try removing both the EGR valve and the IAC valve and give them a good cleaning with a sensor safe carb cleaner. An EGR gasket with an integrated screen can be purchased that will reduce the tendancy of carbon deposits from hanging up the EGR valve.
Thanks for your help swartlkk, I plan on ripping it apart and cleaning them tomorrow, hope it helps my truck.
89 Blazer Lebanon
09-26-2012 10:41 AM
