IS THERE ANY DIFFERANCE??
IS THERE ANY DIFF. BETWEEN THE TBI 2.8 OR A ELECTRIC CARB 2.8???IF SO WHAT WOULD IT BE AND WOULD THE PARTS BE INTERCHANGABLE TOO??? LIKE HEADERS,INTAKE,OR CAM,ANYTHING THAT COULD BE MORE POWERFULL FOR ME TO UPGRADE ON IT???
MY BLAZER USE TO HAVE A TBI NOW ITS A DIFF.MOTOR WITH A ELECTRIC CARB SO I WAS TOLD BY A MECHANIC BUT THATS ALL HE WOULD SAY ABOUT IT... |
RE: IS THERE ANY DIFFERANCE??
First, lets look into getting that CAPS lock button fixed...
And there is a HUGE difference between them. In fact, they are completely different. If it was originally equiped, you just have to hope that everything is still there to get it working again... |
sorry for the caps lock my wife uses this puter too lol,what do you mean its not originally equiped its the 89 s10 blazer you told me that its a carb instead of tbi thats in it it runs really good and strong to be that old of an motor, but its only got 60k on it
*Combining Consecutive Posts* also would it be a 90 degree or is it still a 60im looking at??? |
Your truck originally came with TBI and the motor was swapped out for an older one. What I am saying is that you need to make sure that all of the connections are still there as well as a working PCM to control it. Who knows what was done when the motor was swapped. You can just hope that no permanent changes to the wiring/computer. It is going to be a royal pain to figure out.
You will likely need a TBI intake, throttle body, possibly the fuel line, and whatever electrical wiring that is no longer there. Your best bet would likely be to find another 89 at a local junkyard and either pull everything from it, or use it as a reference to figure out what you need to do with yours. The 2.8L v6 is a 60 degree v6. |
Up till 1985 the 2.8s had a smaller main bearings design compared to the 1986-1993 2.8s. Also in 1986 with the new fuel injection the 2.8 got a small head change being bigger valves. Overall the early motors are fine but the best ones are the 86-93 motors. All exterior parts will swap out between them, just not the crank and related parts, and you don't wanna run one carb and one fuel injected head.
If your wanting more power ditch the 2.8 and find a 1993-1995 with a 3.4 v6 and use the short block with the fuel injection from the s-series. |
thanks neo,that helped out alot so you wouldnt have any pics i could use to see whats there and whats not there all i know is that the motor was switched out and nothing else was done to it or any wires cause there is several wire plugs just lyeing on the driver side and the a/c plugs have been disconnected,im looking just to get it running better with what is there like getting the dash panel to work so i can start saving up to do some bigger work under the hood i already have a small system thats going in it but i want everything to work first befor i did the system
thanks alot though neo |
www.autozone.com register your truck info and there will be some wiring and vacuum diagrams for it.
but I can post some pics of my 87 if needed but mines had some work done to it so its not all stock. |
hey if almost all the wires are connected on the driver side that would be a blessing just so i can see whats what and wheres where im checking out auto zone now but i would really like to see some good clear pictures plugs and connectors on the driver side so thanks for the info
would i need a engine wire harness or will the orignal work with this motor set up???which harness would i need cause i called the junk yard and they kept asking which harness i need and i told them the main engine harness from the pcm to the engine and they asked me again which specific harness
