tranny fluid
Old Jan 26, 2012 | 02:40 PM
vendo's Avatar
vendo is on a distinguished road
Default tranny fluid
Does the tranny fluid go in between the transfer case and trans? my tranny was 4 quarts low and i saw no leaks,is there a seal or any way fluid is leaking into transfer case 1992 Blazer K5
Old Jan 29, 2012 | 06:50 PM
radiokid's Avatar
radiokid is on a distinguished road
Yes you could have trans fluid leaking into the transfer case, if the seal is leaking.
It takes the same fluid however it could be under pressure removing the filler nut on the case should let you know if the tranny is leaking into the case if fluid comes out the top then you know its leaking, or if you have to much fluid in the case. however the trans and Tcase do not share fluid between the two.
Old Jan 30, 2012 | 04:32 PM
vendo's Avatar
guess i will have to take the bolt out...
Old Jan 30, 2012 | 07:31 PM
xgiovannix12's Avatar
make sure you remove the filler plug not the drain one
the filler plug is on top
Old Jan 31, 2012 | 05:45 AM
vendo's Avatar
Lol thats a good one,I grew up in a car dealership....al
Old Jan 31, 2012 | 08:02 AM
lol just making sure. I did not mean you did not know what you were doing
Im apologies if it was taking in the wrong way
Old Feb 16, 2012 | 01:12 AM
Matthew Hayes's Avatar
Matthew Hayes is on a distinguished road
Mine does this exact same thing. It overfills the transfer case and the transmission starves for fluid. So it's probably a bad seal?
Old Feb 16, 2012 | 10:57 AM
richphotos's Avatar
Yuppers
Old Feb 16, 2012 | 12:12 PM
Mag-300's Avatar
Mag-300 is on a distinguished road
My Granddad bought a 2000 s-10 4x4 a few years back.It only had around 20,000 miles on it.When we stopped and started to pull up steep hill's it would just sit and the engine would race.
No smoke or spinning of the tires like you'd expect.Finally we put it in 4 wheel low.
Then it would go.
After several time of this happening and continuously checking the tranny fluid which was never low he had an idea.
He remembered the old power glide we had in our 64 chevy.
You had to keep power braking it lightly forward and back to get the true fluid level.
We did this with his truck and bingo it was about 2 and 1/2 quarts low.
I never would have thunk it but man that truck does great still.
Just a small story that may help in the future.
BrinkDiamond
Mar 2, 2014 03:50 PM
ski.dive
Feb 7, 2014 05:18 AM
DaleA
Jan 13, 2009 08:50 PM
timetoblaze
Nov 2, 2006 01:33 AM
LT1KICKER
Oct 23, 2006 04:00 PM
