-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   tranny type (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/tranny-type-74846/)
coolcat0285 Oct 29, 2012 10:04 AM
tranny type
I bought an 89 blazer 4x4 4.3L v6 2 weeks ago since day one the tranny has been slipping, so from what i learned with everyones help. just replace it i'm guessing it's a 700/r4 but would like someone with more knowledge to confirm that before i go buy the wrong tranny. thanks
chris015 Oct 29, 2012 10:16 AM
Its is indeed a 700r4.
Before you go looking for one in a junkyard remember this secret to compare if its a 700 or a 4l60e. If you look on the drivers side of the tranny,you'll see a big plug in. If its square its 700r4,if its round its a 4l60. If you are looking for one in a pull it yourself yard,only get one from a vehicles thats been wrecked,or you know for sure the engine is siezed. that doesnt mean you are getting a good one but the odds are more in your favor.
AndrewO1991 Oct 29, 2012 10:25 AM
:icon_ditto: 700r4. Make sure to get another 4x4 trans. Dont try to convert. Not worth it. 4.3 shares the bellhousing with sbc's as well. Relatively easy to find.
chris015 Oct 29, 2012 10:28 AM
ah yes^
you CAN convert it but you MUST swap out the main shafts that run all the way through the tranny. its not as simple as swapping the tail. Man i wish it was. If you can swap these,you might as well rebuild the trans yourself as everything has to come out.
ohsofly Oct 29, 2012 05:16 PM
Yup, make sure its from a 4x4. You can pull it from fullsize trucks as well...
coolcat0285 Oct 30, 2012 02:01 AM
will a 700 out of a 85 blazer 4x4 2.8 work on my 4.3 4x4
AndrewO1991 Oct 30, 2012 07:10 AM
Nope. Different bellhouseing
neo71665 Oct 30, 2012 11:39 AM
Personally i would look for one out of a fullsize v8 over a v6 one. They are built a bit better. While you working on it put a trans cooler on it also.
http://image.hotrod.com/f/techarticl...mage_large.jpg
60 (2.8, 3.1, 3.4)degree on left 90 degree (4.3, v8s) on right
trobbins Oct 30, 2012 03:39 PM
dosen't one from a camaro fit also
neo71665 Oct 31, 2012 01:48 AM
Yall have many 4x4 camaros around your parts?
