-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   using a paperclip in 1994 4.3 w S-10 (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/using-paperclip-1994-4-3-w-s-10-a-88639/)
wanderlust2 01-23-2015 03:24 PM
The check engine light on in my 1994 4x4 S-10 4.3 w auto and I've read conflictive reports about using a jumper (a paperclip) because the 94/95 models were different. The connector on mine is of the 12 pin design. The engine starts fine but idles rough. An Actron CP9145 scanner supposedly works but I can't find one. So if any 1994 owners have info on this I would appreciate your replies.
ussexplorer 01-24-2015 10:11 AM
Hmmmm
12 pin is correct for chevy pre-odb II connector. If this works. The link below shows you both types and you jump B & A with ignition off. Then turn on but don't start. Then the check engine light should flash a code.
https://search.yahoo.com/search;_ylt...yfp-t-901&fp=1
Josh
chris015 02-02-2015 03:31 PM
It'll work.my 94 did. Top far right 2 prongs. Dont start it with the clip in.
