Vacuum Diagram
I'm lost in vacuum land. I have a million splitters, some capped off, and what appears to be some incongruencies in what I THOUGHT was connected before I went to AutoZone and what can no longer be connected the way I thought it was... if that makes sense.
1994 Chevy S-10 Blazer 4.3L "W" with what I think is the "evap canister" on the passenger side, near the front, not attached to the actual hood. (It appears theres about 1.2 billion configurations for this guy). I've found a page with 30 diagrams on autozone's web site, but I'm not real sure which one applies... if ANY of them do. Can anyone please help?! |
RE: Vacuum Diagram
I dont have an actual diagram but i think i can walk you through most vaccum lines
first from the back of the intake manifold it splits within an inch one to a four way tee with a one way valveand the other im not sure it is a hard plastic. from the four way tee one to the "vaccum ball" second is hard plastic to the heater/AC control, third goes to the cruise control, fourth goes back to the transfer case then back to the front for the four wheel drive system. hope this helps. |
Same issue
5 Attachment(s)
I'm in the same boat as the original poster. I have the 2wd though. Automatic transmisson. My issue is when I'm looking at all the diagrams provided on autozones website. They referance things such as "Engine vacuum schematic-1994 4.3L(VIN W) engines with A/T (Code TDU)" Of course I know my engine and transmisson but what I dont understand are the CODES. There is Code TKS, Code TDS, Code TDM, Code TDU, and Code TNA. How in the world am I suppose to know which one I have..Hmmmm I have posted the diagrams as well.
Thanks in advance Forum noobie!! |
It appears to me that you can narrow it down some by checking the valve covers. The three diagrams on the left show PCV tubing going to both of them.
There's a link on here somewhere to help you read your RPO codes...ie TDU..etc. Your codes are probably in the glove box on a sticker. |
I have A 1991 S10 blazer 4.3l, 4x4- I have a vacuum line loose and do know where it goes. Do anybody have a Vacuum diagram for this year model.
vacuam head aches
please help i have 1993 s-10 blazer w/4.3L 4wd i need a complete vacuum diagram does anyone know where i can find one
| All times are GMT -5. The time now is 07:06 PM. |
