vaule covers
is it a big job to replace them on a 92 s-10 blazer
RE: vaule covers
NO NO and HELL NO. If you have the correct tools these are easy. But why are you replacing the covers or just the gaskets...either way. All you have to do is have the correct socket size extension length and the strength to twist crap out of the little buggers.
There are two styles since I don't know what you have. here goes. One style has 4 bolts along the outside edge of the valve covers. The newer style has three(?) nuts in the center of the valve cover, so depending on who put them on last and with how much force, they should come off pretty easy..... |
RE: vaule covers
check out my post entitled leak.another member told me it might be the vaule covers leaking down
HERE |
RE: vaule covers
Hey, maybe you should keep this in that thread then. Please do not create threads on EVERY thought you have. You can group them together. I count over half of your posts that can be combined with others.
RE: vaule covers
On a personaly note/question anyone got a good spot where I can buy some nice looking valve covers...anyone have pics of a blazer with aftermarket vc on?
RE: vaule covers
sorry swartlkk still kinda new at this.
RE: vaule covers
hey rooster again i believe u said u have the tbi 92, then u have three bolts running on the top of the covers. u might as well change both covers gasket. that way u know for sure that they other one wont leak as well. there are though some brackets and things u must remove first. the most important of which is ur tv cable bracket. make sure u dont pull on the cable or its adjuster, if so just readjust after u install. plus i like to use rtv around the covers flange for added support, u just have to let that dry before completing the cover install(before u put them on the truck.)
RE: vaule covers
are there any pics on here of someone replacing the vaule covers on there truck
RE: vaule covers
I would just to out and spend 15 bucks on a haynes manual and you wouldn't have to ask every question that you think of, and you even get pics on lots of things.
RE: vaule covers
only problem in my opinion is that theres a lot of stuff going on around them valve covers (at least in my 97). you have to pull some cables out of the way and stuff before you get to them, but when you have everything out of the way its easier than tieing your shoes!
