Very Odd Situation
Old Feb 25, 2009 | 07:53 PM
88hurstolds's Avatar
88hurstolds is an unknown quantity at this point
Default Very Odd Situation
My VIN W 94 Blazer is really acting weird.
When I start it up it will run rough and sometimes backfires, I will run it for about 10 miles and will do it when the car is warmed up.
Here's the catch, when I turn off the car for 10 minutes, start it up again and it will run perfectly normal after it is warmed up...
I am getting a code 23 from the computer which is Manifold Air Temperature or something along those lines.
My question is if it is a bad O2 sensor would it throw a code or is it something more like a bat MAT sensor?
I'm thinking it's a bad O2 sensor but I don't want to be throwing money at it if it's something simple...
Thanks!
Old Feb 25, 2009 | 08:05 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Default RE: Very Odd Situation
from the book I have on my 94:
code 23: MAT low temp indication, sets if the manifold air temperature sensor connections or wires are open for 3 seconds
that being said I'd start by unplugging the wires and make sure the connections are not corroded if so clean them and plug em back in if that does not work try the air charge sensor (the problem when mine had this code) with it acting normal after being shut off and restarted I would lean more toward a corroded or loose connection.
Old Feb 26, 2009 | 09:41 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
it also isnt hard to change out that senor and it isnt that expenive either. mine was throwing out that code and it was a mixture of the connector being broken and it needed to be replaced.
lityjohn701
Feb 10, 2014 08:54 PM
LowLife
Feb 12, 2011 05:19 PM
DFEMS2
Sep 5, 2010 05:40 PM
SuperBlazer
Nov 27, 2009 01:45 PM
Raanerud
May 6, 2009 06:49 AM
