-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   vortec 4.3 knock sensor location VIN W (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/vortec-4-3-knock-sensor-location-vin-w-45191/)
rocknroadie 06-01-2010 05:59 AM
I've got a '92 jimmy that's throwing a code 43, but I can't even find the second knock sensor to test it.
The one I found is the one in the passenger side cylinder head, which seems to be OK. I've read that the other one is supposed to be in the vicinity of the distributor cap (some say below, some say to the right of,) but no amount of poking around there has lead me to find it.
They say a picture is worth 1000 words, can someone post a pic of where it's supposed to be, so I can (hopefully) stop bloodying up my hands with this thing and move on the the next job?
I wouldn't be surprised if the previous owner pulled it for some reason and just threaded a bolt in where it was supposed to go... he was that way.
swartlkk 06-01-2010 06:38 AM
The image below shows the location of the rear knock sensor on the 96+ SCFI engines:
http://i11.photobucket.com/albums/a1..._Locations.gif
Your second sensor could be in that location.
Also, my references show the possibility of it being located in the back of the cylinder head... It is a bit unclear. But that should get you closer.
Bigchief 09-02-2010 06:14 PM
I am trying to find the location of the knock sensor on my 96 Chevy Blazer. Can not find it. Can somone please help with a pic.
swartlkk 09-02-2010 06:34 PM
Did you look at the picture posted above?? Its clearly pointed out.
btb1003 07-01-2011 02:40 PM
On my '93 S10 4X (W) the second is located on the back of the passenger side cylinder head and a beast to get to
mxpxpunkrock1987 07-01-2011 06:19 PM
passenger side lower part under exhaust manifold the one u are refering to is the cam sensor which is known for causing problem which is located on disty
