Does your dome light also stay on? If so, you could have a bad door sensor/pin.
Hi there,
since yesterday my Warning Buzzer / Peeper ( what ever it called ) for the lights / Doors stays on when the lights are on and the engine is running, Door´s closed. I hate to drive with this sound all the time, so i found out that the buzzer is located under the dash left side and i cut the grey wire ( for now ) Any ideas what this could be? Thanks in advance Bad Bear 1992 Blazer S10 4x4 4Dr. 4,3 TBI |
Nope, dome lights are all off, Door pins should be all ok, tried every door, sound is going on.
Bad Bear |
