01 blazer wipers stopped working
Old 12-19-2009, 08:59 AM
jstutzman's Avatar
jstutzman is on a distinguished road
Default 01 blazer wipers stopped working
i checked the fuse. When i unplug the 5 pt harness under the hood, the wiper motor jumps a little then agian dies. I have done a search and read thru a couple of posts and many think it is a resoldering issue with a control board. I do this stuff for a living so it is not an issue. Someone mentioned a wiper fix thread in the diy section that explains where the board breaks or needs fixed. I cant find it. Could someone fill me in on where the card is, what needs fixed or where the thread is that has that info. Thanks.
Old 12-19-2009, 09:52 AM
Fix for cold solders in the Wiper Motor
That should help. Check some of the link out in my signature for more helpful DIY threads.
Old 12-19-2009, 02:42 PM
jstutzman's Avatar
well i thought i found the problem. It looked like it was a cold solder joint, but that did not fix the problem. What are the voltages on the pins connecting to the card, so i can make sure they are correct.
Old 12-19-2009, 03:02 PM
You would have to have someone back probe the wiring at the motor to get the respective voltages. I found wiring diagrams from two different sources which show resistors in the system, but do not state the resistance value.
Old 12-19-2009, 03:07 PM
jstutzman's Avatar
is it common for these modulator cards to go bad. Should i just replace it and do the motor next. Are the motors common to go out? I really need to get it fixed pretty quick.
Old 12-19-2009, 03:15 PM
The solder joints are the main thing that happens...
Can you help the wipers to get them going?
Old 12-19-2009, 03:20 PM
jstutzman's Avatar
no, they are completly dead. when i pull on them, nothing happens
I have a problem in my other truck where they stick a little or stop and i can go out and tug on the wipers a little and they will start right up. With this one they are dead and nothing will get them working. One time when i plugged the harness into the pulse board the motor jumped about two inches and stopped
Old 12-19-2009, 03:25 PM
Sounds like the motor doesn't think it is back in its park position...
I would try removing the motor assembly and see it if works without it being hooked up to the rest of the wiper drive system
Old 12-19-2009, 03:27 PM
jstutzman's Avatar
okay, ill give that a try. Any good writeups on how to pull that out?
Wiegand
05-11-2012 01:48 AM
Wiegand
05-09-2012 10:18 AM
Jonas
08-09-2010 06:29 PM
ehumpy
16
07-23-2009 07:15 PM
acedrr03
TrailBlazer GMT360/GMT370 (2002-2009) Tech
01-17-2008 10:37 AM
Quick Reply: 01 blazer wipers stopped working
