'02 Blazer heater fan only works on 2 and 3
but not 1 and 4??? any ideas guys???
sounds like blower motor resistor...it mounts just to the right of the blower motor if your standing in front of truck.
if you do a search on it you may find a how to and some info to verify before buying a part.
thanks for the reply sir
Hi doesn't go through the resistor.
Check your underhood fuses, there's a 30a for just high speed. And a relay that's actuated in "4".
Not running in "1" would be the resistor
That or the speed switch is faulty
Thanks for the correction...i learned soemthing on this one too.
Maxboost25psi
03-04-2013 12:22 PM
dconnor.cfh
04-07-2012 10:48 AM
STARMAN
03-30-2011 05:26 PM
rsterrn
11-15-2010 08:53 AM
