04 AC Low Pressure Valve Replace, Add AC Oil on recharge?
You should only add oil if you are replacing a major component that would hold a considerable amount of oil (compressor, condenser, evaporator, or lines). If the system has already leaked down or you have had it evacuated and are only replacing the valve, you should not need to add any oil.
christine_208
15
06-08-2018 02:17 AM
c6159b
10-11-2011 03:30 PM
