1996 blazer gas leek
Old 04-09-2005, 08:23 PM
dobbist's Avatar
dobbist is an unknown quantity at this point
Default 1996 blazer gas leek
ok i have a 1996 4 dr s-10 4x4 that had a bad fuel pump. i replaced the fuel sending unit/pump myself and while i was dropping the fuel tank i broke the "roll-over vent valve" (replaced with one i got from chevy dealership) but every time i go to fill up on gas it leaks from around the area of the new vent valve. so i'm wondering if i just installed it wrong or do i / should i put some silicone or liquid gasket around it to seal it better.
also im not sure if i hooked up the lined all right to the sending unit i know the fuel feed is right but not sure if the evap and return lines are in the correct spot. any help here is really appreciated.
Old 04-10-2005, 03:26 AM
LoLoS10Blazer87 is an unknown quantity at this point
Default RE: 1996 blazer gas leek
Yeah silicone is always good when installing a gasket. Blue RTV would prolly work the best.
You can find a wide variety of silicones and gasket sealers at your local AutoZone. Sorry, just had to do that As Patrick says, I'm the AZ spokesman, lol.
Old 04-10-2005, 11:37 PM
dobbist's Avatar
alright so you say i can but do you think thats just a gasket type leak and nothing more?
98blazerb
06-20-2012 09:53 PM
starandrose
09-22-2010 06:25 PM
crazycz
01-30-2010 10:47 AM
SnowRemorse
01-04-2008 11:26 AM
rmon
02-20-2006 12:42 PM
Quick Reply: 1996 blazer gas leek
