1997 Blazer mechanical questions
Hi everyone!
I have a whole laundy list of things that are wrong or just annoying about my beloved Blazer.
There is a nasty thunping sound coming from under the truck. It happens when I go over a bump or take a sharp curve. The sound is similar to the sound when you bottom out. You can also feel the thumps in the floorboard.
The second thing is the truck won't come up to temp. the teperature guage reads between the 100 and 210 mark and stays there. I have changed the thermostat and all the hoses are hot after running so water is moving through the radiator and heater core. Any ideas?
The anti-lock brakes are out. I have pulled the fuse so it's just power brakes but it seems like it's just tearing through brake pads. I've had the truck for three years and I've changed the pads twice.
One final thing. The gas guage doesn't work. There's also a gas leak coming from the gas tank. The leak doesn't drip to the ground so I'm thinking the gasket where the fuel pickup drops in the tank is the culprit. IS this where the float to operate the gas guage is? Could these two problems be fixed with one time dropping the tank out and replacing everything in the fuel pickup?
Thanks!
Thanks!
Hi everyone!
Thanks!
Thanks!
John Mongelli
04-27-2010 12:32 AM
azn_hispa_dude
10-24-2007 12:11 PM
