ATF Fluid change to late?
So the blazer has just about 95k miles and has never been changed, i know its debated weather or not to change it this late in the game, i would not flush it just drop the pan and replace the filter, and fill it back up, ive herd horror stories of it finishing off a trans from dislodging stuff. Thoughts?
Fluid, filter and gasket is fine, but no flush. Dropping the pan will only take about 5 quarts to refill, roughly half of the entire capacity. You'll get tons of opinions on this subject... I service a fleet of about 10 4L60E transmissions every 36,000 miles. I haven't had a problem with any of them, several are over 200K miles and one of them has over 370K miles.
Thanks it looks a little tight in there, will the pan drop without having to move the exhaust? Also does any one know where i could find a replacement pan with a drain plug in it?
Dorman 265-811 - Amazon.com - $40.74
That is the deep pan so make sure you get the appropriate filter if you have the short pan.
I've never been a fan of flushing transmissions, especially high mileage transmissions. Sometimes the debris that has settled out into different areas is the only thing keeping the seals in those areas from leaking.
I changed my fluid and filter for the first time about 4k miles before it needed to be rebuilt. (96 jimmy ~73k miles when the filter was changed) I don't know if it was ever done before I got the truck and I don't know if it was coincidence, but I'm just sayin...
Yea thats what im worried about
Yea..And it wasn't a flush...just a change and filter. It's actually in the shop right now. Lookin at $1750.
If a transmission goes bad after a simple pan drop & filter change (and nothing was damaged during that process), it wasn't going to be functioning long anyway. Typically, people most often try to cure transmission problems by doing a filter change instead of doing a fluid/filter change as preventative maintenance. That very rarely works.
Have a transmission flushed typically means by using a machine to clear out all of the old fluid, replacing it with new. Often, these machines use an ultrasonic pulse through the lines to loosen junk from inside the transmission during the flush and that can cause more problems than it cures.
