1998 Chevy Blazer rattling sound during cold start
Old 09-12-2014, 03:02 PM
98blazeGar's Avatar
98blazeGar is on a distinguished road
Default 1998 Chevy Blazer rattling sound during cold start
Every now and then, after a rainy day or during a cold day like today, when I turn on my Blazer, it makes a rattling noise. When I step on the gas, the noise speeds up and gets a little louder, but eventually goes away after a it's warmed up. Any help? I can post a video if that'd help, just want no more troubles with my baby.
Old 09-12-2014, 03:28 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
where is this noise coming from, You are very vague describing it.
A video would also help.
Old 09-12-2014, 03:44 PM
newguy's Avatar
Thats funny mnie has been doing this since last winter. First started on a 5- zero morning. Goes away within a few minutes
Old 09-12-2014, 05:01 PM
98blazeGar's Avatar
You think there's anything wrong with it? Something that I should be worried about ASAP?
Old 09-12-2014, 05:02 PM
98blazeGar's Avatar
Sorry, it sounds like it's coming from under the hood, in front of the radiator fan. I think it's called a timing belt? I'll try to get a video soon.
Old 09-12-2014, 07:09 PM
newguy's Avatar
Could be a bad pulley bearing. its a serpentine belts also
Old 09-16-2014, 04:43 PM
dman001948's Avatar
dman001948 is an unknown quantity at this point
I have a 2000 Lt Blazer 4x4 with 106K miles on it 4.3 eng. I bought the blazer in 2002 and still have it. It has made that noise every since I bought it and I have change everything out on the front on the motor. Still there...A mech friend of mind put a tool against one of the valve covers and said it was a lifter or lifters...I still drive it noise an d all...
Old 09-16-2014, 09:23 PM
Not sure if it's the cause of your engine noise, but, piston slap is very common on 4.3L & 5.3L GM engines. The noise generally ocurrs when engine coolant and ambient temps are both ~40F or colder. It can last from a few seconds, to almost a minute. It is most noticeable in neutral, while increasing the RPM, (usually slowly is enough to notice). If you let off the throttle, the noise is almost undetectable, and you may or may not notice it at idle. Piston slap is caused by a lack of lubrication to the lower cylinder walls on cold start up. When the piston is at BDC, (bottom dead center) the tips of the piston skirts extend below the lower end of the cylinder wall. As the piston begins moving upward, the skirts contact the cylinder wall as the piston centers itself in the cylinder bore. Some engines have this problem right from the start, others develop the noise as the engine wears, and some never do it at all. The use of a good quality, fully synthetic motor oil, changed regularly ~4K miles, will usually keep the wear in check, or quiet it down completely. Don't expect immediate results though. Depending on how severe the piston slap is, I've seen them last in excess of 200K miles rattling like that. The "fix" is rebuild it and hope for the best.
BuddyS
03-27-2013 10:11 PM
macbeth765
08-16-2011 11:05 PM
DaveHearne
06-15-2010 10:32 PM
dubv25
08-11-2009 08:45 AM
Calgary ZR2
01-10-2008 01:15 AM
Quick Reply: 1998 Chevy Blazer rattling sound during cold start
