1999 Blazer 1-2 Shift
Old 01-26-2014, 05:56 PM
JasonGoneFishing's Avatar
JasonGoneFishing is on a distinguished road
Default 1999 Blazer 1-2 Shift
After getting off the expressway today, stopping at the light, then taking off, I noticed something different in the shift from 1 -2. It takes a while to shift from 1-2, it finally makes the shift at 25mph. Shifts are fine after that.
Any suggestions?
Blazer has 28,000+ actual miles.
Old 01-26-2014, 06:43 PM
If there are DTC's in memory, it might help with diagnosis. If there are no DTC's, it could be the 1-2 shift solenoid sticking, or the spool valve sticking in the transmission valve body. There's a GM Technical Service Bulletin addressing the sticky spool valve on certain 4L60E transmissions, check with a dealer to see if yours is involved.
Old 01-26-2014, 06:48 PM
The P0410 came back but we cleared it again till I get it replaced. I will check out the bulletin. Thanks
Old 01-26-2014, 06:54 PM
Could it be the transmission speed control sensor? I had it at AutoZone and they said it may be a possibility.
Old 01-26-2014, 07:00 PM
P0410 is a problem with secondary air system, nothing to do with transmission shifting. If the VSS, (vehicle speed sensor) has a problem, you would notice other problems related to: speedo inacuracy or erratic, ABS trouble, cruise control, and all shift points would be affected. Very doubtful it's the VSS.
Old 01-26-2014, 08:18 PM
Will I damage anything by driving it?
Old 01-27-2014, 05:13 PM
High harsh shifts put undue stress on driveline components. Might want to have a trustworthy, competent trans shop take a look at it.
Old 01-27-2014, 05:47 PM
schrack's Avatar
schrack is on a distinguished road
Might also want to check your throttle position sensor, it helps control the transmission shifts. Good Luck
Old 01-28-2014, 08:02 AM
Took the Blazer to Mr.Transmission, they said its on its way out. There is a burnt smell, color is still good. I can tell a big difference between Sunday and today when shifting. Mr.Transmission wants $1800-$2500, a friend of mine will do it for $1200 with a 12 month warranty.
Old 01-28-2014, 05:09 PM
Keep us posted on the outcome.
Quick Reply: 1999 Blazer 1-2 Shift
