1999 blazer check engine light (egr code)
I just bought a 1999 blazer, after a week or so the check engine light went on. Ran the code and it came up EGR Valve. Checked the valve and it appeared like it was recently changed, not much carbon at all, cleaned it anyway, and reset the code. good for a day or so then the engine light came back on again. This time i switched the EGR valve with on from my other blazer (was working perfectly) this was good for a few days. Now the engine light is back on again. Im a little stumped. could it be clogged EGR ports? or something else? how do i clean the ports? where are they located.
any help would be appreciated. (I forgot to mention the blazer runs fine even with the light on, no apparent problems).
thanks
thanks
hi
checked the code last night. I made the assumption when it went on that it was the same code i was getting all along. To my surprise it wasn't, new code was 410, (secondary air injection system). Just coincedence I guess, truck runs fine with light on. what does it do? I'm guessing I'll have to change my injection pump? not familiar with this at all.how hard is it.
thanks
thanks
optimus485
05-12-2012 07:07 PM
givemesnow
08-01-2011 02:54 PM
Kage0113
07-05-2008 07:28 PM
