1999 Blazer ZR2 stopped while driving
1999 Blazer ZR2 stopped while driving. Error P1351
I used my old 1999 Blazer ZR2 the other day and while driving the car lost all power. This happened when i was driving over a speed bump if that matters.
The car cranks over but will not start. There is no sound like the car is going to start at all. It is like there is no power signal or no fuel..
It behaves like if the immobiliser was on but i have checked and it is not on.
Today 07.04.18 a friend did a diganose and it shows error code P1351 (temporary fault). We cleared the code but it comes back on after we tried to start the car
When the immobiliser is active the yellow securety text that sits on the gauge panel is on/lit all the time and when you turn the immobiliser off the yellow securety text turns off after about a second. On my car the immobiliser is behaving correct.
When i tried to start the car i could smell gasoline,
The owner before i bought the car changed the fuel pump so i do not think it is any probem with the fuel pump.
When driving to the store and back home i have noticed that the car seems to misfire a little but only on short drives.
I have not checked the distributor cap yet
I will ask a friend of mine to bring his Wurth diagnose/fault code reader and check if he can find anything. If the Wurth diagnose/fault code reader can be used on my car that is.
Any of my fellow member here that have any idea what the problem might be?
I wouldn't be too quick to rule out the fuel pump. If the previous owner used cheap parts then it could very well have failed already.
Start with the cheapest/easiest thing it could be and go from there.
Let us know if you pull any codes.
Good luck.
Good luck.
IN order for your truck to run right you need the proper amount of fuel, spark and air.
Pull a spark plug wire at the plug and check that you have 1" of strong blue spark with a properly grounded spark tester. If not check at the cap. If not check at the coil. Do this first since you smell gas after you rule out a leak. Be careful with spark in the presence of leaking gas and/or in a confined space
Do the fuel pump test in the sticky if spark is OK. As mentioned, the fuel system can be deficient even if the pump is new and even if you smell gas.
George
George
When you first turn the key, do you get the ~2 second prime? If so, do a good visual inspection of your fuel lines (especially right under the pinch weld on your firewall) and the fuel pressure/leakdown test (link below in my signature block). The fact it happened right after going over a bump and the fact that you are smelling fuel could indicate damaged fuel line (there are areas they get terrible rust).
A friend of mine that is a car mechanic came over to my house this evening and he had his diagnose test computer in his X5 so we did a test and the error code that came up is P1351 (temporary fault)
He erased the error code but it came back on as soon as we tried to start the car.
We took out one spark plug wire and put a spark plug in it and cranked the car while holding the spark plug to metal and no spark at all.
I have not taken off the distributo cap to check it and the rotor but i have a feeling that the problem lies there.
Especially now after we checked that there is no spark at all.
We checked the fuel pump and you can hear it start and operate as it is supposed to but i have not pressure tested it
We took outon spark plug wire and put a spark plug in it and cranked the car while holding the spark plug to metal and no spark at all.
