2000 Blazer approching 90,000 miles..need help!!
Old 04-29-2007, 09:50 PM
lionel2's Avatar
lionel2 is an unknown quantity at this point
Default 2000 Blazer approching 90,000 miles..need help!!
Is there anything special i should be doing to my blazer when it hits 90,000 miles? I am due for an oil change in about 900 miles and i just passed inspection for this year, new K&N air filter, i know i need a new battery and tires...as far as maintanance is there anything else i need to do to my blazer??..what kind of battery should i get by the way?? and i know i will be getting Uniroyal Cross Country tires set of 4...thanks for the help!!!
Old 04-30-2007, 02:21 AM
erauto is an unknown quantity at this point
Default RE: 2000 Blazer approching 90,000 miles..need help!!
Service the diffs, t case, transmission.
Old 04-30-2007, 03:27 AM
Mr Blazer LT is an unknown quantity at this point
In addition to the above, I would do plugs, caps, rotors, chassis lubrication if it's been a few thousand miles since last, check belt, check brakes, that's off the top of my head. No need to upgrade your battery for a bigger/powerful one really, unless you like to run your stereo with the blazer off.
Old 04-30-2007, 09:31 AM
lionel2's Avatar
Yeah i do need to service my differentials both the front and rear diffs...chassie lube is not a bad idea, i already had my plugs,wires, rotor, cap and belts and hoses all replaced with new ones...yes i do run heavy car audio so i do need like a deep cell, like an optima yellow top or something..thats the only one i know that comes in a group 75 size...thanks
ski.dive
01-23-2014 01:35 PM
kiwiblazer
12-22-2009 05:19 PM
BlazeringSaddles
12-05-2009 09:46 PM
cameronp29
08-22-2007 09:30 PM
jamie333
11-08-2006 03:47 PM
Quick Reply: 2000 Blazer approching 90,000 miles..need help!!
