2000 Blazer no spark but cranks fine
Ive got a 2000 chevy blazer that just recently stopped starting. It was driven to work, and then after when i went to start it, it clicked like the battery was dead and then when jumped it just cranked. Replaced the fuel filter and the pump primes ao its still good, but its not getting spark at all. Tested at the plugs and it just recently got new plugs and wires.
Work your way backwards from the plugs to find out where the failure is occurring:
no spark at plugs
is there spark at the coil output?
is there pulse input to the coil
is there pulse input and proper power to the ICM
you can also go the other way and start at the ICM
George
no spark at plugs
George
...and what brands of the spares did You use? You haven't mentioned the distributor, but, as, for example, I've ordered a distributor rotor once. Brand new, came with "made in china" sign. By looking the quality I've decided to stay with the old, worn out one. There were already some topic where people posted the photos of the poor quality distributor not matching or falling apart.
The problem turned out to be a hole burned in the middle of the cheap replacement rotor. The spark was going to the distributor shaft instead of the spark plugs.
He couldn't figure it out. I did.
1acetour
08-07-2023 10:36 AM
abe_f
04-01-2013 11:19 PM
LO3671
04-04-2010 01:26 AM
