2000 GMC Jimmy hose locations
Old 02-28-2012, 02:56 PM
tmnc78's Avatar
tmnc78 is on a distinguished road
Default 2000 GMC Jimmy hose locations
Hi I need to know where these 2 vacuum hose connect to. The first is for the actuator under the battery but the 2nd one I don't know where it goes.
Attached Thumbnails 2000 GMC Jimmy hose locations-photo0109.jpg   2000 GMC Jimmy hose locations-photo0108.jpg
Old 02-28-2012, 06:46 PM
vic98blazer's Avatar
vic98blazer is on a distinguished road
it goes to the nipple right at the pcv valve, on the valve cover its tough to see with the air intake tube in the way. (for the second pic)
Old 02-28-2012, 07:00 PM
tmnc78's Avatar
OK thanks alot. I will check it out tomorrow.
Old 02-28-2012, 07:16 PM
Can't tell for sure in image, but it might go to the reservoir in the left inner fender, near the hood hinge.
Old 02-28-2012, 08:04 PM
tmnc78's Avatar
that one is hooked up but this hose comes from the same connector, it seems to go towards the other side
Old 02-28-2012, 08:14 PM
Off the engine it goes to a check valve with a tee on it. One side of the tee goes to the reservoir, the other goes to another tee. One side of that tee goes to the HVAC in the dash, the other goes to the 4x4 solenoid.
Old 02-28-2012, 08:57 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
The hose in the first picture gives vacuum to the transfer case for your 4x4. The line leaves that solenoid and goes as one piece to the transfer case. It has an identical size hose returning from the transfer case to your vacuum actuator under the battery. The second picture is of the hose for your vacuum for your secondary air injection system under the radiator.
Old 02-28-2012, 08:58 PM
tmnc78's Avatar
Everything looks connected but here is a different angle.
Old 02-28-2012, 09:01 PM
Chevy33's Avatar
What I just posted is as I said, I just worked on these just 2 days ago. That line in the picture you just posted goes down the solenoid for the secondary air injection.
Old 02-28-2012, 09:04 PM
tmnc78's Avatar
thanks,i fixed the hose for the actuator today. i bought the jimmy last week and found these hoses cut.
bdude273
11-22-2013 08:30 PM
AndrewO1991
08-29-2013 05:12 PM
86TransAm
14
12-13-2011 07:46 PM
londonmazda
10-19-2010 02:15 AM
rob1621
04-03-2008 08:55 PM
Quick Reply: 2000 GMC Jimmy hose locations
