2001 4LO ok but no 4HI or AUTO
Old 12-09-2005, 02:48 AM
DaveInDaytona's Avatar
DaveInDaytona is an unknown quantity at this point
Default 2001 4LO ok but no 4HI or AUTO
I have a 2001 2 door Blazer ZR-2 and it has developed a 4WD issue. I can engage 4LO without a problem, but when I select 4HI or Auto the lights just blink for a while then switch back to 2HI.
I'm guessing it's some kind of module but I'm not sure where to look. Any ideas would be appreciated.
Thanks,
Dave
Old 12-09-2005, 12:57 PM
Hanr3's Avatar
Default RE: 2001 4LO ok but no 4HI or AUTO
Welcome to the site.
I have not had to fix a broken modual yet. However it should be located in the t-case. Someone else should be able to provide more info on it.
Old 12-10-2005, 05:35 PM
jinx_walker is an unknown quantity at this point
try disconnecting your battery and resetting the computer. see if it works then...if it dows its probably the shift motor control module...thats what it was in my truck
Old 12-27-2005, 08:54 PM
Thanks for the replies and the welcome. (been out so sorry for my slow reply)
I disconnected the battery, no difference. I found the TCCM and unhooked and checked the connections on it and see no difference. I do hear it "click" when I change from 2HI to 4HI but it doesn't seem to do anything and the 4HI light flashes for a while before returning to 2HI. It works the same on Auto 4WD
When going to 4LO the transfer case changes to LO, but I'm not sure the front engages, it seems that it's really in 2LO.
I'm still in debug mode, any help is apprecaited.
Old 12-30-2005, 12:01 AM
4lowlife's Avatar
I had the same problem. When the "service 4wd" lamp came on I was on dry pavement in 2hi. I took out the tccm and found that one of the chips on the board looked burnt out. A friend who works at a dealer, says they can "go" sometimes. He says he use to replace the shift motor only to find out it was fine and then replace the tccm. So I ordered one from Autozone ($339.00?) and it was from a salvaged vehicle. A new tccm from the dealer was about 60.00 more. It immediately worked.
My tires were quite worn and replaced them with a taller set. About 2 days later It wouldn't engage into 4auto. (it's winter here.) I took it out back in 4hi and spun the wheels in the muck. Now its fine.
Anywho, take it somewheres where you can see front wheel slippage. Even in some wet grass, i.e. your neighbors. There you'll see if the front is engaging. Take the cover off the tccm and look closely at the cicuits. Any sign of discoplored chips may indicate it's shot.
You can drive w/ it disconnected, but only in default, 2 hi. Good luck, happy four wheelin'!!!
Old 01-06-2006, 11:01 PM
I think this one is heading to the dealer.
I did the disconnect tricks, checked connections, etc. and still no 4WD. I can get what looks like 4LO from looking at the lights, but it's really 2LO because the front never engages.
Also sometime during this diagnosis the A/C has stopped working. I have fans, but the compressor never comes on. I know it's winter, but I live in Florida.
Old 01-06-2006, 11:06 PM
That sucks man. Hope they don't take you for a ride! Good luck.
Old 01-06-2006, 11:19 PM
I was told $50 for diagnostics and they would apply it to the repair if they did it.
I'm thinking if they tell me what's wrong I'll do it. I've got way over $50 of my time and frustration in this already so it seems like a bargain.
jms
10-23-2011 11:33 AM
poepoe624
01-10-2010 11:48 AM
Alterac
08-25-2008 08:48 PM
hulses10
12-05-2007 01:32 PM
bobslsc
11-22-2007 11:16 AM
Quick Reply: 2001 4LO ok but no 4HI or AUTO
