2001 Blazer O2 Sensor Question
Old 01-28-2008, 12:03 PM
Default RE: 2001 Blazer O2 Sensor Question
Didn't **** me off in the least, just gets discouraging sometimes when I have to keep repeating things. LOL
Good luck! Don't forget to reset the codes before you purchase anything new!
Old 01-28-2008, 12:28 PM
Majew10's Avatar
Majew10 is an unknown quantity at this point
thanks haha also another question...i have a failed thermostat...my temp gauge only reads 170 and I got the code P0128...where is the thermostat located at
Old 01-28-2008, 12:42 PM
Follow the upper radiator hose. It'll go behind the A/C compressor and back up to the t-stat housing.
Old 01-28-2008, 06:52 PM
Majew10's Avatar
replaced the o2 sensor and the thermostat and drove it for about 5 miles and the SES light went off. Will it stay off or do I still need to get it cleared.
Old 01-28-2008, 07:41 PM
Majew10's Avatar
also thanks for the help everyone
Old 01-28-2008, 07:51 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
No the light should stay off. If the PCM resets the light, that means that the PCM ran through the tests that it needed to, and did not find a fault, so it reset itself. The code will be in history for something like 200 key cycles, but that should not concern you!! Glad you got it fixed, and happy motoring!!
GM hater
01-09-2010 02:32 PM
theeviltwinn
10-23-2009 06:37 AM
Bybsurfr32
09-23-2009 09:12 PM
daniel010
02-02-2009 06:50 AM
Spartan66
07-11-2008 02:34 PM
Quick Reply: 2001 Blazer O2 Sensor Question
