2001 Chevy Blazer 4.3 4x4 stalled while driving and refuses to start
Old 12-20-2010, 02:00 PM
Please be specific when giving the results of tests which were requested.
The next step would be to align the timing marks on the crank per the 96+ Engine Timing thread found in the Tech Article (DIY) Index link in my signature and then check to see if the rotor tip lines up with the '6' in the base of the distributor housing.
Old 12-21-2010, 11:42 AM
Bajaclaw012's Avatar
Bajaclaw012 is on a distinguished road
I aligned the marks as requested, and according to the timing thread. The rotor points close to the #2 spark terminal. Just before the "6" marking.
Old 12-21-2010, 12:17 PM
Have you tried resetting the rotor position such that it points directly at the '6' in the distributor base?
Old 12-21-2010, 12:40 PM
No. I can try. Before i do, should i rotate the crank another 360 degrees to see where the rotor lines up after that? Maybe im on the exhaust stroke, or would that make a difference..
Old 12-21-2010, 01:36 PM
It does need to be on the compression stroke.
Old 12-21-2010, 05:43 PM
One thought. If the timing chain did skip, wouldn't the relation of the cam and crank be slightly off mechanicaly wise? So by resetting the rotor position such that it points directly at the '6' in the distributor base wouldn't the cam still be off slightly per stroke of the piston?
Old 12-21-2010, 06:16 PM
If the timing chain has jumped, yes. If you have not moved the distributor and it is off by that much, that seems to confirm that the timing has skipped unless the gear on the bottom of the distributor is badly worn.
Old 12-21-2010, 06:21 PM
No previous removal of distributor. It's actually brand new from the auto parts store, only 6 months old. Car was running perfect as stated in beginning of thread, than just died. No knocking sounds, just that intermitant backfire.
Old 12-21-2010, 06:24 PM
Then the distributor being off means that something has skipped. Your possibilities are the timing chain or the distributor drive gear.
Old 12-21-2010, 06:34 PM
Thanks so much for guiding me in the right direction, i'll post the results soon. Thank you for your time and knowledge swartlkk !
Quick Reply: 2001 Chevy Blazer 4.3 4x4 stalled while driving and refuses to start
