2002 Blazer Brake Issues
Old 10-04-2014, 07:35 AM
blackbear's Avatar
blackbear is on a distinguished road
Default 2002 Blazer Brake Issues
Hi. New here and need some help.
Changed out front calipers and hoses. When I went to bleed, sprung a leak in the rusted line to the rear. Replaced that. I've bled the brakes in the proper sequence (RR,LR,LF,RF) several times both engine off and engine running. (Open bleeder, push pedal, close bleeder).
Have pedal when off, basically none when running. I'm stumped. I see things in the archives about needing a scan tool to bleed out the ABS with similar issues but nothing to indicate that solved the problem.
I really don't want to have it towed to the dealer if there are any other options.
Blackbear
Old 10-04-2014, 07:41 AM
Sounds like the master cylinder ran dry and you now have air in the MC. It will need to be bled separately to get the air out. This is typically done on a bench with small jumper lines directing fluid back into the reservoir, but can be done with the MC in the truck.
Old 10-05-2014, 09:54 PM
swells244's Avatar
swells244 is an unknown quantity at this point
I had the same problem and had to bleed out the abs unit.I was lucky enought to have a friend with the proper scan tool that could do it.
Old 10-07-2014, 06:49 AM
blackbear's Avatar
Gravity bled the brakes a couple times, all seems to be working now.
Blackbear
c5demon
11-27-2013 08:33 AM
jrmst50
05-13-2013 09:25 AM
skygodtj
05-23-2012 09:08 PM
sqeeks
08-24-2011 06:36 PM
Quick Reply: 2002 Blazer Brake Issues
