2002 Blazer - Loud bang when disengaging from 4WD Hi to 2WD
I have a 2002 S10 Blazer (3 Button).It shifts into 4WD Hi fine but when I go to put it back into 2 wheel there is a delay, sometime several miles and the a loud bang like someone hit the bottom of the vehicle with a hammer. I have changed out the vacuum front axle actuator (under the battery) and I am in the process of changing the Front Axle Actuator Solenoid Valve, which I currently can't locate on the vehicle (it's not on the firewall).
Am I replacing the right items and is there anything else that I need to look at?
What about a vacuum switch on the transfer case? (Not sure if thats what it's called)
how many times are you going to ask the same question? find the thread that you started it in and keep it on there.
https://blazerforum.com/forum/2nd-ge...ocation-84200/
<snip>I have a 2002 S10 Blazer (3 Button) and I am in the process of changing the Front Axle Actuator Solenoid Valve, which I currently can't locate on the vehicle (it's not on the firewall).
It's the 4 button version that uses the firewall mounted solenoid, not the 3 button ones.
I'm not a mechanic, but it sounds like it's your shift motor acting up.
Bono4783
02-04-2014 02:12 PM
ComputerNerdBD
13
12-02-2011 07:12 PM
spaceapex
10-21-2010 07:48 AM
