2002 Headlight dim
This may have been covered already but, Just bought a 02 Blazer that has dim left side headlights (low & High beam) so i bought 2 replacement bulbs and installed them and still have 2 dim headlights on the left.......Passenger side works fine and so do the left side marker lights on the same wire harness.
Where do i start looking ?
The conections at the bulbs are secure and i see no damage to the wire loom......help
Just pulled out the airbox and checked the ground and it was good. Would the relay under the hood go bad on 1 side and cause this ?
Last edited by rriddle3; 05-26-2010 at 02:16 PM. Reason: COMBINING CONSECUTIVE THREADS
Dim Headlight
Added a new ground wire from the low beam and it still dont work right, i just shut the hood because the wife said i shouldnt be out there cussing at it....lol
So i'm going to add a ground to the high beam side and see if it fixes it because the relay was good.
ITS FIXED !!!!! lol
Turns out there is another 15 amp fuse for the headlights in the relay box under the hood.
Now i can start adding my touches to the inside and out, My 97 Blazer was quick and it was a 4x4, This thing is a 4x2 and its a damn rocket ship.....
