2002 ZR2 Blazer Hesitation Problem
Vehicle has a good hesitation between 1500 and 2000 rpms only. Otherwise, runs fine. Fuel filter, spark plugs, air filter have been changed. Vehicle has only 40,000 miles on it. Any suggestions for this repair would be highly appreciated.
RE: 2002 ZR2 Blazer Hesitation Problem
check mass air flow sensor, and trans fluid
Wouldn't mass air flow sensor throw a code? Why would this cause it at only these rpms, wouldn't it happen constantly? As for transmission fluid - fluid is full - why would fluid do it as these rpms only anyway?
check for corrosion on the terminals on the coil pack, or the wires may be bad.
jimhens82
06-22-2015 10:30 AM
skygodtj
05-23-2012 09:08 PM
wahhen
06-10-2005 10:56 PM
