2005 Chev Blazer 4wd Front lower ball joints
Old 06-07-2013, 03:52 PM
joejiz's Avatar
joejiz is on a distinguished road
Default 2005 Chev Blazer 4wd Front lower ball joints
Hi
Shop said my lower ball joints are going, how much are the parts and labour on this typically?
I can feel the truck not stay on track and can feel the in the steering wheel the road more.
Any idea?
Old 06-07-2013, 04:13 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
parts about 40-65 per ball joint, as for labor.. I am not sure on that one. being its the lowers, a bit more involved than the uppers. especially if they have never been replaced before, and are still riveted.
Old 06-07-2013, 04:22 PM
Moog, (good quality stuff) lower ball joints (K5335) ~$60.00 each.
Flat rate labor time is 1.7 hours per side, plus an alignment.
If you're planning on keeping the vehicle, use Moog parts, not some el cheapo knock off China junk. Ball joints are not something to cut corners on trying to save money.
EDIT: Depending on your local labor rate, total should be ~$450.00
Old 06-07-2013, 04:52 PM
joejiz's Avatar
Default Thanks
Awesome, thanks!!! Appreciate it
Old 06-07-2013, 08:22 PM
rexazz2's Avatar
like said , if you plan on keeping it use better quality parts
The labor is the same just less chance of ever needing to do it again and having to pay the labor a second time
Old 07-31-2017, 05:29 PM
joejiz's Avatar
I bought all killer top of the line parts, upper and lowers and new pitman arm, all new p/s fluid. and alignment... very tight
BlackOnBlack
06-24-2008 11:52 PM
jimmyboy
Suspension Tech
13
12-27-2007 11:11 PM
Aquahallic
11-16-2007 10:29 AM
Jorgen
07-24-2007 08:40 AM
bigbrett
09-19-2006 10:16 PM
Quick Reply: 2005 Chev Blazer 4wd Front lower ball joints
