2005 Chevy Blazer ABS Brakes ?
Old 03-07-2011, 10:06 AM
mwindrider1's Avatar
mwindrider1 is on a distinguished road
Default 2005 Chevy Blazer 4.3 Vortec
Thanx old skool
Old 03-08-2011, 06:31 AM
old skool luvr's Avatar
how exactly did your friend determine that the ABS code is result of the fluid? did he tell you what the code was?
i have just under 150K miles on my '98, and it's never had the brake fluid flushed, other than the bleeding i did when i replace the rear calipers.
and putting your phone # up for a reply? not really a good idea, IMO. any yahoo that is surfing the net can now have access to your name & #.
Old 03-09-2011, 03:50 PM
Norm277's Avatar
Norm277 is on a distinguished road
I think your friend is way off track. I had the same issue in a previous vehicle and it ended up to be a bad wire at the wheel sensor. It's also possible that it's the sensor itself.
Norm
Old 03-09-2011, 04:23 PM
while it is recommended to change the brake fluid in your vehicle (every couple of years i think) i can't see the actual fluid being the issue.
find out the codes & do a search (either here on the forum, or with your friend).
Old 04-04-2011, 07:58 PM
Default 2005 Chevy Blazer ABS Brakes ?
Can wore down brake pads cause your ABS lights to come on ?
Thanx ! mwindrider1@yahoo.com
Old 04-04-2011, 08:12 PM
warthogdriver's Avatar
well, wrong area for this.
yes if you brake fluid is low it could come on.
prob should be looking into some pads
Old 04-04-2011, 09:15 PM
So wore out brake pads or could it be possibly super dirty sensor from brake pads causing ABS lights to come on ?
Thanx !
rwgottar
11-24-2013 08:33 PM
2005blazer13
09-11-2013 04:05 PM
hobie204
05-09-2009 01:38 PM
Ronmacd
12-19-2008 10:23 AM
fla_blazer4x4
07-22-2008 06:57 PM
Quick Reply: 2005 Chevy Blazer ABS Brakes ?
