95-97 compatability?
I just bought a 97blazerLS I was going to use for parts for my 95LS. The 97 is in better shape and runs much stronger so I'm going to use my 95 as parts.
My Q is, will my power seats work in the 97? will they wire up easy? The 97 has no power seats.
Also the 97 doesn't have the Tach. will my gauge cluster from the 95 swap into the 97 without any issues?
Will my 95 trans be a direct swap into a 96? both are auto's 4x4's and 4drs. I believe it will.
Thanks
Jason
Thanks
Jason
RE: 95-97 compatability?
IIRC the seats should be the same. I know on my 2000 the plug for the power seats is under both seats but i have manual seats. As for the cluster i would think it should work but of course you will have the issue of the odometer being wrong. Any of our senior members had the dash of those apart recently???? Lastcoupe are you around to shed any light on this?
Lastly the trans, it should be a 4L60E trans's and they should be interchangeable.
Anybody?
I'd have to say get under there and measure some things out. IIRC, the transmissions changed somewhere along the way between '95 and '98...
