95 blazer getting no fire to coil pack
I just replaced my coil pack and distributor cap and rotor button on my 95 blazer 4.3 L.
it will turn over and is getting fuel but getting no spark to the coil pack could it be the wire that runs from the coil pack to the distributor cap ?? Please somebody help me i been with out a truck now for 6 months . had to replace all the fuel system fuel lines brake lines. Was bought from someone who was from up north and was in snow and salt. Im in florida .
Your ignition system consists of a 12v control section where the engine computer takes sensor inputs and tells the ignition module when to initiate a spark. The ignition module the tells the coil with a 12v signal to initiate the spark. The coil then outputs a very high voltage level that is capable of jumping the distributor gap and in turn the spark plug gap. You need to determine if the problem is in the high voltage section from the coil to the plugs or the low voltage section from the sensors to the coil.
the correct way to test high voltage is to form a 1” gap to ground and crank the truck over to check for 1” of strong blue spark. You start with a plug wire pulled from a plug. If no spark then pull the high voltage lead going into the distr from the coil and repeat the test. If no spark then your problem is a faulty coil or in the low voltage control section between the sensors and the coil low voltage/primary circuit. Report back on the high voltage/secondary tests and we can go from there.
Proper diagnosis is preferred over blindly swapping parts as I have suggested here but if you prefer to swap parts, then replace these one at a time:
ICM
crank position sensor
George
ICM
George
monette999
09-12-2013 11:18 AM
